Charge or sync micro USB mobile devices from a standard USB port on your desktop or mobile computer. The UUSBHAUB6IN 6-inch USB A to Micro-B cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems) and a USB-capable computer, for everyday tasks such as data synchronization and file transfers.
- StarTech.com 6in Micro USB Cable - A to Micro B - USB to Micro B - USB 2.0 A Male to USB 2.0 Micro-B Male - 6-inches - Black (UUSBHAUB6IN) - USB cable - USB to Micro-USB Type B - 15 cm
- USB cable
- Length
- 15 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: PIB2M21, PIB2MS1, PIB2S31, USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBPLATE4, USBUB2PCARB
- USB cable
- American Wire Gauge (AWG)
- 30
- Length
- 15 cm
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
|  | StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £4.66 |
|  | StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
|  | StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.00 |
|  | StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £25.34 |
|  | StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £46.54 |
|  | StarTech.com USB Wall Charger 17W / 3.4A x2 | In Stock | £14.50 |
|  | StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £60.78 |
|  | StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £108.12 |
|  | StarTech.com 2x USB Wall Charger 17W / 3.4A | In Stock | £14.55 |
|  | StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £125.14 |
|  | StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £61.67 |
|  | StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £43.92 |
|  | StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £54.82 |
|  | StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £12.20 |
|  | StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £39.13 |
|  | StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.45 |
|  | StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £30.29 |
