StarTech.com 6in LP4 to P4 Auxiliary Power Cable Adapter
Quicklinx: 7RWXWS00 Mfr#: LP4P4ADAP
Length: 15.2cm
Type: Power
£4.38 ex VAT
£5.25 inc VAT
This 6in LP4 to P4 Auxiliary Power Cable Adapter turns a female LP4 connector into the male P4 connector needed for connecting to a Pentium 4 motherboard. This cable adapter is constructed of top quality materials and designed for durable performance.
  • Efficient connection
    This adapter connects a 4-pin internal power to a 4-pin ATX12V connector, providing a reliable solution for systems in need of power adjustments.
  • Robust design
    The sturdy construction ensures durability and reliability when expanding power connections within cramped PC environments.
  • Standard compliance
    Meets FCC compliance standards, assuring users of safe and effective performance in various applications.
StarTech.com 6in LP4 to P4 Auxiliary Power Cable Adapter - LP4 to 4 pin ATX - Molex to P4 Adapter - LP4 to P4 (LP4P4ADAP) - power adapter - 4 pin internal power (5V) to 4 pin ATX12V - 15.2 cm
Power adapter
Length
15.2 cm
Connector
4 pin internal power (5V) - female
Connector (Second End)
Power 4 pin ATX12V connector - male
Power adapter
Length
15.2 cm
Connector
FCC
Length: 15.2cm
Type: Power
