This LP4 to LP4/SATA Power Y Cable Adapter (PYO1LP4SATA) features an LP4 male connector that splits into one female LP4 power connection as well as a SATA female power connection, providing a cost-effective way to interconnect a SATA device (hard drive, optical drive etc.) as well as a device requiring a female power connector (i.e. IDE drives, etc.), to a legacy power supply that doesn't natively offer the necessary connections. Expertly designed and constructed of only top quality materials.
- StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter - Power splitter - 4 pin internal power (M) to 4 pin internal power, SATA power (F) - 5.9 in - PYO1LP4SATA - power splitter - 15 cm
- Power splitter
- Length
- 15 cm
- Connectors
- 4 PIN internal power - male
- Connectors (Second End)
- 15 pin Serial ATA power - female , 4 PIN internal power - female
- Limited lifetime warranty
- Designed For
- P/N: 35BAYUSB3S4, SATSASBAY3BK
- Power splitter
- Length
- 15 cm
- Connectors
- RoHS
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.48 |
StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 | In Stock | £3.10 |
