StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Cable Adapter
Quicklinx: 7WZ1WS00 Mfr#: LP4PCIEX8ADP
£8.90 ex VAT
£10.68 inc VAT
Convert a standard LP4 power supply connector to an 8-pin PCI Express video card power connector. The LP4PCIEX8ADP 6-inch LP4 to 8-Pin PCI Express Power Adapter converts a standard LP4 power connector on your existing power supply to an 8-pin PCI Express video card power connector, allowing you to install a PCIe graphics card without having to upgrade the computer power supply.
StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Cable Adapter - lp4 to PCI express - molex to 8 pin PCIe (LP4PCIEX8ADP) - power adapter - 4 PIN internal power to 8 pin PCIe power - 15.3 cm
Power adapter
Length
15.3 cm
Connector
2 x 4 PIN internal power - male
Connector (Second End)
8 pin PCI Express power - male
Power adapter
American Wire Gauge (AWG)
18
Length
15.3 cm
Connector
RoHS
7WZ1 StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Cable Adapter In Stock £4.19
