StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Cable Adapter
Quicklinx: 4JY0WS00 Mfr#: LP4PCIEXADAP
Type: Power
27 In Stock
£4.18 ex VAT
£5.01 inc VAT
Convert a Standard LP4 Power Supply Connector to a 6-pin PCI Express Video Card Power Connector. This 6in LP4 to 6 Pin PCI Express Video Card Power Adapter converts a standard LP4 power connector on your existing power supply to a 6 pin PCI Express video card power connector, allowing you to install a PCIe graphics card without having to upgrade the computer power supply.
StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Cable Adapter - Power adapter - 4 pin internal power (M) to 6 pin PCIe power (M) - 6 in - LP4PCIEXADAP - power adapter - 4 PIN internal power to 6 pin PCIe power - 15.2 cm
Power adapter
Length
15.2 cm
Connector
2 x 4 PIN internal power - male
Connector (Second End)
6 pin PCI Express power - male
P/N: ATX2POWER430, ATX2POWER530, RMC4450, ATX2POW500HS, ATX2POW450HS, ATX2POW400HS, ATX2PW550PRO, ATX2PW500PRO, ATX2PW450PRO, ATX2PW400PRO, MICATXPOW255, ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, RMC2300, MICATXPOW145, ATXPOW250PRO, ATXPOW300PRO, ATXPOWER250, ATXPOWER300
Power adapter
Length
15.2 cm
Connector
StarTech.com 400 Watt Silent ATX12V 2.01 PC Computer Power Supply with 120mm Fan, 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 450 Watt Silent ATX12V 2.01 PC Computer Power Supply with 120mm Fan, 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply, 500 Watt Silent ATX12V 2.01 PC Computer Power Supply with 120mm Fan, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Type: Power
