Add an extra SATA power outlet to your PC Power Supply. The PYO2LSATA 6" SATA Power Splitter Cable features a SATA 15-pin plug that connects to a single computer power supply SATA connector and breaks out into two latching SATA 15-pin receptacles, which enables you to connect two Serial ATA drives to a single SATA power connection on the computer power supply.
The latching SATA power connectors ensure a secured connection to the drives, preventing accidental disconnects, while the Y-adapter power split eliminates the cost of having to upgrade the power supply to accommodate an additional SATA drive.
The PYO2LSATA is constructed of only top quality materials and designed for optimum performance and reliability.
- StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F - 6 inch Serial ATA Power Cable Splitter - SATA Power Y Cable Adapter - power splitter - SATA power to SATA power - 15.24 cm
- Power splitter
- Latched
- Length
- 15.24 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 2 x 15 pin Serial ATA power - female
- Limited lifetime warranty
- Designed For
- P/N: 35S24M2NGFF, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S32M2NGFFPEX, SAT32MSATPEX, SATSASBP425
- Power splitter
- Latched
- Length
- 15.24 cm
- Connector
- RoHS
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.40 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.42 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.40 |
