StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F
Quicklinx: 8K0DWS00 Mfr#: PYO2LSATA
Length: 15.24cm
41 In Stock
£5.60 ex VAT
£6.72 inc VAT
Add an extra SATA power outlet to your PC Power Supply. The PYO2LSATA 6" SATA Power Splitter Cable features a SATA 15-pin plug that connects to a single computer power supply SATA connector and breaks out into two latching SATA 15-pin receptacles, which enables you to connect two Serial ATA drives to a single SATA power connection on the computer power supply.
The latching SATA power connectors ensure a secured connection to the drives, preventing accidental disconnects, while the Y-adapter power split eliminates the cost of having to upgrade the power supply to accommodate an additional SATA drive.
The PYO2LSATA is constructed of only top quality materials and designed for optimum performance and reliability.
  • Secure latching mechanism
    The latched design ensures a stable connection that prevents disconnections, enhancing the reliability of powered devices.
  • Versatile power distribution
    With one male connector and two female connectors, this cable allows for easy connection to multiple Serial ATA devices, simplifying power management.
  • Environmentally compliant
    Meets RoHS standards, providing an eco-friendly choice while ensuring safety and reliability in your electronic setup.
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F - 6 inch Serial ATA Power Cable Splitter - SATA Power Y Cable Adapter - power splitter - SATA power to SATA power - 15.24 cm
Power splitter
Latched
Length
15.24 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
2 x 15 pin Serial ATA power - female
P/N: 35S24M2NGFF, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S32M2NGFFPEX, SAT32MSATPEX, SATSASBP425
Power splitter
Latched
Length
15.24 cm
Connector
RoHS
8K0D StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
8K0D StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.60
Length: 15.24cm
