StarTech.com 6in DVI-I Dual Link Digital Analog Port Saver Extension Cable M/F
Quicklinx: 76M0WS00 Mfr#: DVIEXTAA6IN
Extend a DVI-I port by 6in, to prevent unnecessary strain on the port. The DVIEXTAA6IN 6-inch DVI-I Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DVI cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
The 6in DVI-I cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
Designed and constructed for maximum durability.
StarTech.com 6in DVI-I Dual Link Digital Analog Port Saver Extension Cable M/F - DVI-I Male to Female Extension Cable - 6 inch - 2560x1600 (DVIEXTAA6IN) - DVI extension cable - 15.2 cm
DVI extension cable
Length
15.2 cm
Connector
DVI-I - male
Connector (Second End)
DVI-I - female
RoHS
DVI extension cable
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
15.2 cm
Connector
24+5 pin combined DVI - male
24+5 pin combined DVI - female
RoHS
76M0 StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £11.12
