Extend a DVI-D port by 6in, to prevent unnecessary strain on the port. The DVIDEXTAA6IN 6-inch DVI-D Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DVI cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
The 6in DVI-D cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
- StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F - DVI-D Male to Female Extension Cable - 6 inch - 2560x1600 (DVIDEXTAA6IN) - DVI extension cable - 15.2 cm
- DVI extension cable - dual link
- Length
- 15.2 cm
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - female
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Length
- 15.2 cm
- Black
- Connector
- 24+1 pin digital DVI - male
- 24+1 pin digital DVI - female
- RoHS
- Designed For
