The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
- StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter (DP2MDPMF6IN) - DisplayPort adapter - 15.2 cm
- Molded
- Length
- 15.2 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- Mini DisplayPort - female
- RoHS
- Limited lifetime warranty
- Designed For
- P/N: SV231DPU, SV231DPUA
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 32
- Molded
- Length
- 15.2 cm
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2, RoHS
- Designed For
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F
