StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter
Quicklinx: 3ZLFWS00 Mfr#: SATAPOWADAP
Length: 0.2m
Type: ATA
More than 50 in stock
£2.95 ex VAT
£3.54 inc VAT
This 6in 4 Pin (LP4) Molex to SATA power adapter cable features one 4 Pin Molex (LP4) male connector and one female SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
StarTech.com 6in 4 Pin LP4 to SATA Power Cable Adapter - power cable - 0.2 m
Power cable
Length
0.2 m
Connector
15 pin Serial ATA power - male
Connector (Second End)
4 PIN internal power - male
P/N: ATX2POWER430, ATX2POWER530, BRACKET25SAT, RMC4450, ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, RMC2300, ATXPOW250PRO, ATXPOW300PRO, ATXPOWER250, ATXPOWER300
Power cable
Length
0.2 m
Connector
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Length: 0.2m
Type: ATA
Price Range Ex VAT: 0 - 50
