StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter
Quicklinx: 78W9WS00 Mfr#: SATAPOWADAPR
£4.18 ex VAT
£5.01 inc VAT
This 6-inch 4-pin (LP4) Molex to right angle SATA power adapter features one 4-pin Molex (LP4) male connector and one (female) right angle SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
StarTech.com 6in 4 Pin LP4 to Right Angle SATA Power Cable Adapter - LP4 to SATA - 6in LP4 to SATA Cable - 4 pin to SATA - power adapter - SATA power to 4 PIN internal power - 15 cm
Power adapter
Right-angled connector
Length
15 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
4 PIN internal power - male
P/N: HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA
Power adapter
Length
15 cm
Connector
78W9 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
78W9 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
78W9 StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.34
78W9 StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
78W9 StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable Adapter In Stock £4.02
78W9 StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.34
