StarTech.com 6ft VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 3ZKCWS00 Mfr#: MXT101
Type: VGA
Length: 1.8m
35 in stock
£3.84 ex VAT
£4.60 inc VAT
This high quality 6ft SVGA/VGA monitor extension cable features a high density D-Sub male (HDD15 male) connector and a D-Sub female (HDD15 female) connector, allowing you to extend a VGA cable connection by 6ft. The VGA monitor extension cable supports video resolutions up to 800x600 dpi.
StarTech.com 6 ft VGA Monitor Extension Cable - HD15 M/F - VGA extension cable - 1.8 m
VGA extension cable
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
Grey
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
VGA extension cable
Length
1.8 m
Grey
Connector
15 pin HD D-Sub (HD-15) - female
3ZKC StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.91
3ZKC StarTech.com 6ft VGA Monitor Extension Cable - HD15 M/F In Stock £3.84
Type: VGA
Length: 1.8m
Price Range Ex VAT: 0 - 50
