This high quality 6ft SVGA/VGA monitor extension cable features a high density D-Sub male (HDD15 male) connector and a D-Sub female (HDD15 female) connector, allowing you to extend a VGA cable connection by 6ft. The VGA monitor extension cable supports video resolutions up to 800x600 dpi.
- StarTech.com 6 ft. (1.8 m) VGA Extension Cable - VGA Extension - Male/Female - VGA Monitor Cable (MXT101) - VGA extension cable - 1.8 m
- Length
- 1.8 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- Grey
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
- Length
- 1.8 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- Designed For
