StarTech.com 6ft VESA Certified DP Cable
Quicklinx: J1K2WS00 Mfr#: DP12-CABLE-6FTW
15 In Stock
£11.45 ex VAT
£13.74 inc VAT
Enhance your viewing and audio experience with the StarTech.com 6ft White VESA Certified DisplayPort 1.2 Cable with Latches. Designed to meet the needs of high-definition displays, this cable supports 1080p at 240Hz, 2K at 144Hz, and 4K at 60Hz, ensuring clear visuals for gaming, streaming, and professional applications. With support for up to 7.1 audio channels and 8 audio channels, it delivers a rich and immersive audio experience. The latched connectors and EMI protection provide a secure and stable connection, minimizing interference for uninterrupted data transmission. Constructed with a durable thermoplastic elastomer jacket and shielded with aluminum mylar foil and braid, it stands up to demanding environments. Additionally, its support for DisplayPort Multi-Stream Transport (MST) allows for the daisy-chaining of multiple monitors, simplifying your workspace setup without compromising on display quality. Whether for work or play, this DisplayPort cable is a reliable choice for superior audiovisual performance.
  • High-quality visuals
    Experience stunning high-definition visuals with support for 1080p at 240Hz, 2K at 144Hz, and 4K at 60Hz, ensuring a smooth and immersive viewing experience for gaming, streaming, and professional applications.
  • Enhanced audio experience
    With support for up to 7.1 audio channels and 8 audio channels, this cable delivers a rich audio experience, complementing the high-quality visuals for a fully immersive entertainment setup.
  • Reliable connectivity
    Featuring latched connectors and EMI protection, this DisplayPort 1.2 cable ensures a secure and stable connection while minimizing interference, for uninterrupted data transmission.
  • Durable design
    Constructed with a thermoplastic elastomer jacket and aluminum mylar foil with braid shielding, this cable is designed for durability and long-lasting performance, even in demanding environments.
  • Multi-stream support
    Support for DisplayPort Multi-Stream Transport (MST) allows for daisy-chaining of multiple monitors, simplifying your workspace setup without compromising on display quality.
StarTech.com 6ft White VESA Certified DisplayPort 1.2 Cable with Latches - DisplayPort cable - DisplayPort to DisplayPort - 1.8 m
DisplayPort cable
Shielded
Halogen-free, passive cable, 4K60Hz support, 1080p support 240Hz, 2K144Hz support, strain relief, EMI protection, HBR2 support, DisplayPort Multi-Stream Transport (MST), 7.1 audio channel support, ABS housing, 21.6 Gbps data rate, 19 conductors, 3D support, 8 audio channels, daisy-chaining
Length
1.8 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.2
White
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Outside Diameter
7.5 mm
White
142 g
Connector
DisplayPort 1.2, RoHS, WEEE, VW-1, HDCP 1.3
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
1 cm
Shipping Weight
150 g
