Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using the USB-A port on your computer. You can also use the cable to charge your USB-C mobile devices from a standard USB-A wall or car charger.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
Charge and sync your mobile devices over longer distances
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably. -
Provide superior connections with USB-IF-certified cables
The cable has undergone rigorous compliance testing and is certified by USB-IF to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
- StarTech USB C to USB Cable - 6 ft / 2m - USB A to C - USB 2.0 Cable - USB Adapter Cable - USB Type C - USB-C Cable (USB2AC2M) - USB-C cable - USB-C to USB - 2 m
- USB-C cable
- Technology
- Double shielded
- Cable Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, ST4200MINIC
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Cable Length
- 2 m
- Black
- 44 g
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £8.87 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.48 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.24 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £12.99 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £8.64 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £9.97 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £8.81 |
StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £4.59 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £13.39 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.77 |
