Connect your USB Type-C, HDMI or Mini DisplayPort laptop to an HDMI display or projector. This unique adapter cable lets you connect almost any laptop or desktop computer to an HDMI display or projector. It supports the USB-C, HDMI and Mini DisplayPort output from your computer, and video resolutions up to Ultra HD 4K.
The adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This adapter cable is ideal for your boardroom's HDMI display or projector. You can reduce clutter and eliminate the need for multiple adapters on your boardroom table by providing a single adapter cable that can support a variety of signals.
The adapter cable supports multiple input signal types, so you'll be able to accommodate a variety of user needs. Employees and guests can plug in their USB Type-C, HDMI or mDP laptops and deliver their presentations using your boardroom's HDMI display, without having to carry their own adapters.
This adapter cable ensures you can maintain an astonishing picture quality with four times the resolution of 1080p. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
The adapter can be powered through the provided Micro-USB cable by connecting the cable from the adapter to a USB port on your laptop or the HDMI display. You can connect your laptop to either input on the adapter cable, and share presentations.
Simple boardroom setup
This adapter cable is ideal for your boardroom's HDMI display or projector. You can reduce clutter and eliminate the need for multiple adapters on your boardroom table by providing a single adapter cable that can support a variety of signals. -
One adapter for multiple users
The adapter cable supports multiple input signal types, so you'll be able to accommodate a variety of user needs. Employees and guests can plug in their USB Type-C, HDMI or mDP laptops and deliver their presentations using your boardroom's HDMI display, without having to carry their own adapters. -
Astonishing picture quality
- StarTech.com 6ft USB-C, HDMI or Mini DisplayPort to HDMI Adapter Cable - adapter cable - Mini DisplayPort / HDMI / USB - 2 m
- Cable
- Adapter cable - Mini DisplayPort / HDMI / USB
- Length
- 2 m
- Black
- Connectors
- 24 pin USB-C - male , HDMI - male , Mini DisplayPort - male
- Connectors (Second End)
- HDMI - male , Micro-USB Type B (power only) - female
- 4K support, USB power, passive adapter
- 3-year warranty
- Cable Type
- Adapter cable 4K support, USB power, passive
- Interface Supported
- Jacket Material
- Plastic
- Length
- 2 m
- DisplayPort Alternate Mode support
- Black
- Connectors
- 24 pin USB-C - male , 19 pin HDMI Type A - male , Mini DisplayPort - male
- 19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
- Included Accessories
- USB-A to Micro-USB cable
- FCC, RoHS, WEEE, REACH, RCM
- 6 cm
- 1.5 cm
- 222 g
- Shipping Width
- 12.2 cm
- Shipping Depth
- 22.1 cm
- Shipping Height
- 6.7 cm
- Shipping Weight
- 478 g
- Limited warranty - 3 years
StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £4.54 |
StarTech.com 6ft DP Mini DP HDMI to HDMI | In Stock | £94.16 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £267.59 |
