StarTech.com 6ft USB-C mDP HDMI to HDMI
Quicklinx: CQSGWS00 Mfr#: CMDPHD2HD
Connect your USB Type-C, HDMI or Mini DisplayPort laptop to an HDMI display or projector. This unique adapter cable lets you connect almost any laptop or desktop computer to an HDMI display or projector. It supports the USB-C, HDMI and Mini DisplayPort output from your computer, and video resolutions up to Ultra HD 4K.
The adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This adapter cable is ideal for your boardroom's HDMI display or projector. You can reduce clutter and eliminate the need for multiple adapters on your boardroom table by providing a single adapter cable that can support a variety of signals.
The adapter cable supports multiple input signal types, so you'll be able to accommodate a variety of user needs. Employees and guests can plug in their USB Type-C, HDMI or mDP laptops and deliver their presentations using your boardroom's HDMI display, without having to carry their own adapters.
This adapter cable ensures you can maintain an astonishing picture quality with four times the resolution of 1080p. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
The adapter can be powered through the provided Micro-USB cable by connecting the cable from the adapter to a USB port on your laptop or the HDMI display. You can connect your laptop to either input on the adapter cable, and share presentations.
  • Simple boardroom setup
  • One adapter for multiple users
  • Astonishing picture quality
StarTech.com 6ft USB-C, HDMI or Mini DisplayPort to HDMI Adapter Cable - adapter cable - Mini DisplayPort / HDMI / USB - 2 m
Cable
Adapter cable - Mini DisplayPort / HDMI / USB
Length
2 m
Connectors
24 pin USB-C - male , HDMI - male , Mini DisplayPort - male
Connectors (Second End)
HDMI - male , Micro-USB Type B (power only) - female
4K support, USB power, passive adapter
3-year warranty
Cable Type
Adapter cable 4K support, USB power, passive
Interface Supported
Jacket Material
Plastic
Length
2 m
DisplayPort Alternate Mode support
Connectors
24 pin USB-C - male , 19 pin HDMI Type A - male , Mini DisplayPort - male
19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
USB-A to Micro-USB cable
FCC, RoHS, WEEE, REACH, RCM
6 cm
1.5 cm
222 g
Shipping Width
12.2 cm
Shipping Depth
22.1 cm
Shipping Height
6.7 cm
Shipping Weight
478 g
Limited warranty - 3 years
CQSG StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.59
CQSG StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £231.46
