StarTech.com 6ft USB C Charging Cable
Quicklinx: GZ9MWS00 Mfr#: R2CCR-2M-USB-CABLE
Length: 2m
More than 50 In Stock
£8.36 ex VAT
£10.03 inc VAT
This rugged 6ft (2m) USB-C right angle cable can be used to connect and/or charge a USB peripheral. Conveniently connect USB-C enabled devices at a right angle to the cable for organized cable routing solutions.
  • Built for Daily Use
    The durable USB charging cable features aramid fiber reinforcement that protects the cable from the stress of frequent bends. This allows the cable to flex without over-stretching or damaging the core components of the cable.
  • Flexible Strain Reliefs
    The USB cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been tested to withstand over 5,000+ bend cycles at a 180° angle.
  • Superior Connection Quality
    The durable cable supports all USB specifications up to USB 2.0, providing a dependable connection for USB-C peripheral devices. It supports up to 3A for charging USB-C-enabled devices. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 6ft (2m) USB C Charging Cable Right Angle, 60W PD 3A, Heavy Duty Fast Charge USB-C Cable, USB 2.0 Type-C, Durable and Rugged Aramid Fiber, S20/iPad/Pixel - High Quality USB Charging Cord (R2CCR-2M-USB-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
USB Power Delivery (60W), sync and charge, strain relief, EMI protection, Quick Charge
Length
2 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/32
Rated Current
3 A
Plated Connector
Gold/nickel
Length
2 m
Outside Diameter
3.1 mm
10 g
Connector
USB / USB 2.0, DOC, RoHS, WEEE, REACH, EMI
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
3 cm
Shipping Weight
46.5 g
GZ9M StarTech.com USB A to USB C Charging Cable In Stock £6.09
GZ9M StarTech.com 6ft USB A to USB C Charging Cable In Stock £7.84
GZ9M StarTech.com 1ft USB A to USB C Charging Cable In Stock £5.00
GZ9M StarTech.com 6in USB C Charging Cable In Stock £6.38
GZ9M StarTech.com 3ft USB C Charging Cable In Stock £8.57
GZ9M StarTech.com 1ft USB C Charging Cable In Stock £6.63
Length: 2m
