StarTech.com 6ft USB-C Charging Cable, 240W
Quicklinx: J4KLWS00 Mfr#: S2CEPR2M-USBSL-CABLE
Length: 2m
48 In Stock
£14.96 ex VAT
£17.95 inc VAT
Connect a charger or hub to a USB Power Delivery (PD) 3.1-enabled device, using this USB-C Charging Cable. The USB-C charger cord delivers up to 240W of Extended Power Range (EPR) Power Delivery and 5A output for fast charging. The connector markings enable quick visual identification, distinguishing it from other similar-looking or unmarked USB-C cables. Eliminate guesswork and always choose the right Type-C cable to support full 240W charging. This cable features dual locking screws that can securely connect to your USB-C peripherals and can prevent accidental disconnection from your devices. The knurled screws can be removed from the cable completely allowing it to be used as a standard USB-C cable if required. The screws are designed to fit all devices that use a standard side screw locking input. The USB-C EPR Charging Cable features a silicone jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are designed for frequent daily use, and are rated to operate beyond 20,000 insertion cycles. Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 2-meter (6.6-foot) USB Type-C cable is the ideal length for desk and mobile workstations, commuters, in-car use or to reduce clutter when syncing with a USB-C laptop. With up to 5A of output, the USB-C Charger Cord supports up to 240W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
  • Durable design
    The cable is constructed with a thermoplastic elastomer (TPE) jacket and features a rugged design that ensures long-lasting performance even under heavy usage.
  • High-speed connectivity
    With a 480 Mbps data rate, this USB-C cable allows for quick syncing of files along with the capability for fast charging, supporting efficient data transfer and power delivery.
  • Advanced shielding
    The aluminum mylar foil and braid shielding effectively reduce electromagnetic interference, ensuring stable and reliable connections during use.
  • Extended power range
    Supports USB Power Delivery (240 W) and Power Delivery 3.1, allowing for rapid charging of devices with high power requirements.
  • Long-lasting performance
    Designed with a 20,000+ bend lifespan, this cable is engineered to endure the rigors of daily use while maintaining its functionality.
StarTech.com 6.6ft (2m) USB-C Charging Cable, 240W, Silicone Jacket - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
USB Power Delivery (240W), Power Delivery 3.1 support, extended power range (EPR), sync and charge, rugged, fast charging support, wear-resistant, e-marker chip, EMI protection, 480 Mbps data rate, 20000+ bend lifespan, ABS connector housing, halogen free
Length
2 m
Connector
24 pin USB-C - male - straight/locking
Connector (Second End)
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
4.7 mm
84 g
Connector
USB / USB 2.0, USB-IF, RoHS, WEEE, FCC
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.8 cm
Shipping Weight
90 g
Length: 2m
