StarTech.com 6ft USB C Cable 5Gbps Gen1
Quicklinx: GKNMWS00 Mfr#: USB315CCV2M
This USB 3.2/3.1 Gen1 5Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices. The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
  • Power your USB-C devices
    With up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop.
  • Deliver 8K video with DisplayPort 1.4 Alt Mode
    The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions.
  • Charge your mobile devices
    When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them.
StarTech.com 6ft (2m) USB C Cable 5Gbps, High Quality USB-C Cable, USB 3.1/3.2 Gen 1 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB C to C Cord, Charge & Sync - Thunderbolt 3 Compatible (USB315CCV2M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
8K30Hz support, USB Power Delivery (5A, 100W), Power Delivery 3.0 (PD 3.0) technology, 5 Gbps data rate
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.4
Grey, black
P/N: DK30C2DAGPD, DK30C2HAGPD
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Length
2 m
Grey, black
100 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.4, RoHS, WEEE
GKNM StarTech.com Rugged Right Angle USB-C Cable 1m In Stock £27.51
GKNM StarTech.com 3m Active USB-C Cable, USB 3.2 In Stock £46.67
