The 2 m (6.6 ft) White USB-A to USB-C Charging Cable from StarTech.com is designed to meet various charging and data transfer needs. This USB-C cable, compliant with USB 2.0 standards, provides a reliable connection for both charging and syncing devices. With a data transfer rate of up to 480 Mbps, it ensures quick and efficient performance. Built with aluminum mylar foil shielding and a braided design, this cable offers effective EMI protection and durability against wear and tear.
Featuring a rated current of 3 A, it supports USB Fast Charge up to 15 W, making it perfect for powering devices swiftly. The cable's lifespan is rated for 10,000 insertions. It is also crafted from halogen-free thermoplastic elastomer for safety and is certified RoHS compliant. This charging cable is an excellent choice for anyone seeking a combination of performance and reliability.
                Reliable performanceWith a data transfer rate of up to 480 Mbps, this cable ensures fast and efficient syncing of data between devices.
                Fast charging capabilityThe cable supports USB Fast Charge with a rating of 15 W, allowing devices to charge quickly and efficiently.
                Durable constructionCrafted with aluminum mylar foil shielding and a braided design, this cable offers EMI protection and durability against everyday use.
                Long lifespanDesigned for a lifespan of 10,000 insertions, this cable is built to withstand frequent connections and disconnections.
                Eco-friendly materialsThe halogen-free thermoplastic elastomer used in the cable's jacket promotes safety and aligns with environmental standards.
- StarTech.com 2m (6.6ft) White USB-A to USB-C Charging Cable/Cord, M/M - USB-C cable - USB to 24 pin USB-C - 2 m
- USB-C cable
- Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/30
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 2 m
- Outside Diameter
- 3.5 mm
- White
- 45 g
- Connector
- USB / USB 2.0, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1.4 cm
- Shipping Weight
- 50 g
