StarTech.com 6ft USB-A to USB-C Cable
Quicklinx: J1MRWS00 Mfr#: USB2AC2MNCWHE
Length: 2m
40 In Stock
£6.38 ex VAT
£7.65 inc VAT
The 2 m (6.6 ft) White USB-A to USB-C Charging Cable from StarTech.com is designed to meet various charging and data transfer needs. This USB-C cable, compliant with USB 2.0 standards, provides a reliable connection for both charging and syncing devices. With a data transfer rate of up to 480 Mbps, it ensures quick and efficient performance. Built with aluminum mylar foil shielding and a braided design, this cable offers effective EMI protection and durability against wear and tear.
Featuring a rated current of 3 A, it supports USB Fast Charge up to 15 W, making it perfect for powering devices swiftly. The cable's lifespan is rated for 10,000 insertions. It is also crafted from halogen-free thermoplastic elastomer for safety and is certified RoHS compliant. This charging cable is an excellent choice for anyone seeking a combination of performance and reliability.
  • Reliable performance
    With a data transfer rate of up to 480 Mbps, this cable ensures fast and efficient syncing of data between devices.
  • Fast charging capability
    The cable supports USB Fast Charge with a rating of 15 W, allowing devices to charge quickly and efficiently.
  • Durable construction
    Crafted with aluminum mylar foil shielding and a braided design, this cable offers EMI protection and durability against everyday use.
  • Long lifespan
    Designed for a lifespan of 10,000 insertions, this cable is built to withstand frequent connections and disconnections.
  • Eco-friendly materials
    The halogen-free thermoplastic elastomer used in the cable's jacket promotes safety and aligns with environmental standards.
StarTech.com 2m (6.6ft) White USB-A to USB-C Charging Cable/Cord, M/M - USB-C cable - USB to 24 pin USB-C - 2 m
USB-C cable
Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB / USB 2.0
White
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/30
Rated Current
3 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
3.5 mm
White
45 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.4 cm
Shipping Weight
50 g
Length: 2m
