Position your USB 3.0 Micro devices with less clutter and according to your configuration needs, with a thin, more flexible cable. This slim, sturdy USB 3.1 Gen 1 (5 Gbps) cable, also known as a USB 3.0 cable, lets you position Micro-USB devices on your desk without the cable getting in the way. It's thinner and more flexible than standard cables, and features a right-angled Micro-USB connector that prevents awkward bends at the connection port.
Now you can arrange your desk according to what works best for you, without worrying about the cable bending awkwardly or straining too much to make a connection. This durable, lightweight cable is roughly half the thickness of a regular USB 3.0 cable, giving you the flexibility and freedom to place your devices as needed, with minimal clutter.
This versatile cable features a right-angled connector, which offers a more natural fit at the device connection point, preventing unnecessary strain and damage to the port.
Charge your USB 3.0 Micro B-equipped phones and tablets with full charging power, with no increase in charge time, even at a distance of 6 feet (2 meters) away from your charger.
The long cable overcomes distance restrictions and lets you stay connected even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. Plus, the cable's right-angled Micro-USB connector lets you text, work or game on your mobile device even while it's charging, without the cable getting in the way.
- StarTech.com 2m 6 ft Slim Micro USB 3.0 Cable M/M - Right-Angle Micro-USB - USB 3.0 A to Micro B - Angled Micro USB - USB 3.1 Gen 1 5Gbps (USB3AU2MRS) - USB cable - Micro-USB Type B to USB Type A - 2 m
- USB cable
- Technology
- Shielded
- Right-angled connector, sync and charge, 5 Gbps data rate
- Length
- 2 m
- Connector
- 10 pin Micro-USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 26/32
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- USB 3.0, RoHS
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.00 |
StarTech.com 6ft Slim Micro USB 3.0 Cable | In Stock | £10.56 |
StarTech.com 6ft Slim Micro USB 3.0 Cable | In Stock | £12.24 |
