StarTech.com 6ft Right Angle Micro-USB Cable
Quicklinx: BL6XWS00 Mfr#: USB2AUB2RA2M
Length: 2m
Select:
£6.17 ex VAT
£7.40 inc VAT
Charge and sync your Micro-USB device from a hard-to-reach USB port. This Micro-USB cable features two right-angled connectors that let you connect to hard-to-reach ports and also help prevent cable and port damage. The cable is great for charging your mobile devices in a car, or for connecting to peripherals that may be difficult to connect to when using a straight connection.
The right-angled connectors allow you to connect to ports that may otherwise be inaccessible or difficult to reach. Perfect for charging car-mounted mobile devices or for connecting your portable hard drive or other Micro-USB 2.0 device to your computer in such a way that it fits your installation needs.
The angled connectors prevent the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection points, preventing unnecessary stress and damage to the cable and ports.
Charge your USB 2.0 Micro B-equipped phones and tablets with full charging power, with no increase in charge time - even at a distance of 6 feet (2 meters) away from your charger.
The long cable overcomes distance restrictions and lets you stay connected even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. Plus, the cable's right-angled Micro-USB connector lets you text, work or game on your mobile device even while it's charging, without the cable getting in the way.
StarTech.com 2m 6 ft Micro-USB Cable with Right-Angled Connectors - M/M - USB A to Micro B Cable - 6ft Right Angle Micro USB Cable (USB2AUB2RA2M) - USB cable - Micro-USB Type B to USB - 2 m
USB cable
Right-angled connector
Length
2 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
American Wire Gauge (AWG)
24/30
Plated Connector
Nickel
Length
2 m
Connector
USB / USB 2.0, RoHS
BL6X StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.66
BL6X StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.11
BL6X StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.17
Length: 2m
