StarTech.com 6ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJRWS00 Mfr#: DP14VMM2M
Length: 2m
20 In Stock
£14.98 ex VAT
£17.97 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 6.6 ft. (2 m).
  • High performance connectivity
    This DisplayPort cable is compliant with DisplayPort 1.4 standards, ensuring quality transmission for both video and audio. With its HBR3 support, users benefit from enhanced bandwidth for demanding applications.
  • Reliable high-definition output
    Allows for striking visual quality with support for 8K resolution at 60Hz and 4K at 120Hz. This makes it suitable for high-resolution displays and advanced gaming setups.
  • Durable construction
    Features a thermoplastic elastomer jacket and aluminum mylar foil shielding for long-lasting durability and protection against interference, ensuring stable performance during use.
  • Enhanced audio capabilities
    Supports up to 32 audio channels and provides options for both 5.1 and 7.1 audio channel transmissions, delivering a rich acoustic experience for varied audio needs.
  • Versatile compatibility
    This cable is designed for maximum compatibility with various devices, thanks to its VESA certification and compliance with industry standards like HDCP 2.2.
StarTech.com 6ft (2m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM2M) - DisplayPort cable - DisplayPort to DisplayPort - 2 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Length
2 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
34
Plated Connector
Gold
Length
2 m
Outside Diameter
4.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
88 g
GJJR StarTech.com VESA-Certified DP 2.1 Cable In Stock £14.14
GJJR StarTech.com VESA-Certified DP 2.1 Cable In Stock £12.68
GJJR StarTech.com VESA-Certified DP 2.1 Cable In Stock £20.05
Length: 2m
