Connect a high-powered server to a power distribution unit. This C19-to-C20 power cord features 14 AWG wire that's suitable for high-power connections, making it perfect for server applications and connecting to a Power Distribution Unit (PDU).
Plus, you can use the cable to extend the reach of your existing power cord by 6 feet, which gives you the extra distance you need to place your devices according to your server room configuration.
- StarTech.com 6ft (1.8m) Heavy Duty Extension Cord, IEC C19 to IEC C20 Black Extension Cord, 15A 125V, 14AWG, Heavy Gauge Power Extension Cable, IEC C19 to IEC C20 AC Power Cord - UL Listed - power cable - IEC 60320 C20 to IEC 60320 C19 - 1.8 m
- Power cable
- Service Junior Thermoplastic (SJT) jacket
- Length
- 1.8 m
- Connector
- Power IEC 60320 C20
- Connector (Second End)
- Power IEC 60320 C19
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 250 V
- Length
- 1.8 m
- Black
- Connector
- UL, RoHS
