StarTech.com 6ft Angled Lightning/USB Cable
Quicklinx: BFP3WS00 Mfr#: USBLT2MWR
Colours:
Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. This 2-meter (6-foot) angled Lightning cable is great for connecting your mounted mobile devices. You can position it as needed to accommodate your fixed-in-place iPad or iPhone.
Wherever your iPad or iPhone is mounted, this cable provides the flexibility to suit your installation. With an angled Lightning connector, you can position the cable to the left or right of your mobile device in either portrait or landscape mode, without having to worry about straining the connection port.
At two meters (six feet) in length, this convenient cable provides full charging power even at a longer connection distance than most. So, you won't have to endure slow charge times, even when your iPad or iPhone is mounted to a desk, a wall or in your car.
The angled connector positions the cable in such a way that it's easy to access your iPad or iPhone in either portrait or landscape mode, even while charging. Now, you can text, work or game without the cable getting in the way.
The USBLT2MWR Lightning cable is Apple MFi certified.
StarTech.com Angled Lightning to USB Cable - 2m (6ft) - White - Apple MFi Certified (USBLT2MWR) - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
22/28
Length
2 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Angled connector
P/N: USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable angled connector
Interface Supported
Lightning / USB
Double shielded
22/28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
BFP3 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.81
