This 6ft four-in-one DVI/USB KVM cable integrates dual link DVI video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single, compact cable. The 4-in-1 KVM cable is a cost-effective and convenient solution that's suitable for use with dual link DVI supported USB KVM switches, allowing you to share a USB peripheral set between two computers configured for high definition output. The DVI/USB KVM cable provides guaranteed performance for dependable operation.
- StarTech.com 4-in-1 Cable for KVMs with Dual Link DVI and USB - Audio & Microphone Cables Built-in - 6ft (2m) (DVID4N1USB6) - keyboard / mouse / video / audio cable - 1.8 m
- Keyboard / mouse / video / audio cable
- Length
- 1.8 m
- Connectors
- 24+1 pin digital DVI - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- 24+1 pin digital DVI - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
- Black
- Limited lifetime warranty
- Designed For
- P/N: RKCOND17HD, SV231DDUSB, SV231DVIDDU, SV231DVIUAHR, SV231QDVIUA, SV231TDVIUA, SV431DDUSB, SV431DL2DU3A, SV431DVIDDU, SV431DVIUAHR, SV431TDVIUA
- Length
- 1.8 m
- Black
- Connectors
- RoHS
- Designed For
StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone | In Stock | £12.05 |
StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £7.67 |
StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub | In Stock | £385.79 |
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £301.32 |
