StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone
Quicklinx: 6LCHWS00 Mfr#: DVID4N1USB6
Hurry, only 1 left in stock!
£9.54 ex VAT
£11.44 inc VAT
This 6ft four-in-one DVI/USB KVM cable integrates dual link DVI video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single, compact cable. The 4-in-1 KVM cable is a cost-effective and convenient solution that's suitable for use with dual link DVI supported USB KVM switches, allowing you to share a USB peripheral set between two computers configured for high definition output. The DVI/USB KVM cable provides guaranteed performance for dependable operation.
StarTech.com 4-in-1 Cable for KVMs with Dual Link DVI and USB - Audio & Microphone Cables Built-in - 6ft (2m) (DVID4N1USB6) - keyboard / mouse / video / audio cable - 1.8 m
Keyboard / mouse / video / audio cable
Length
1.8 m
Connectors
24+1 pin digital DVI - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
Connectors (Second End)
24+1 pin digital DVI - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
P/N: RKCOND17HD, SV231DDUSB, SV231DVIDDU, SV231DVIUAHR, SV231QDVIUA, SV231TDVIUA, SV431DDUSB, SV431DL2DU3A, SV431DVIDDU, SV431DVIUAHR, SV431TDVIUA
Length
1.8 m
Connectors
RoHS
6LCH StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £9.54
6LCH StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £282.13
