High Definition video, USB, and audio all in one cable.
This 6-foot 4-in-1 DisplayPort/USB KVM switch cable integrates DisplayPort video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single compact cable.
This convenient 4-in-1 KVM cable is a cost-effective solution that's suitable for use with any DisplayPort supported USB KVM switch, allowing you to share display and USB peripherals between multiple computers configured for high definition output.
This DisplayPort, USB, and Audio KVM cable provides guaranteed performance for dependable operation.
 - StarTech.com 6ft 4-in-1 USB DisplayPort® KVM Switch Cable w/ Audio & Microphone (DP4N1USB6) - video / USB / audio cable - 1.8 m
 - Video / USB / audio cable
 - Molded, colour-coded connectors
- Length
 - 1.8 m
- Connectors
 - 20 pin DisplayPort - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
- Connectors (Second End)
 - 20 pin DisplayPort - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
 - Black
 - Limited lifetime warranty
- Designed For
 - P/N: SV231DPU, SV231DPUA
- Plated Connector
 - Gold
- Length
 - 1.8 m
 - Black
- Connectors
 - RoHS
- Designed For
                        StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £7.64 |
                        StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £6.92 |
                        StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.69 |
                        StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
                        StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
                        StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone | In Stock | £11.14 |
