StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI
Quicklinx: GBT2WS00 Mfr#: CDP2HDMM2MH
Length: 2m
20 In Stock
£18.18 ex VAT
£21.81 inc VAT
USB Type-C Adapter Cable HDR10 Ultra HD Thunderbolt 3 Host Compatible. This USB-C to HDMI cable lets you connect your USB Type-C (supporting DP Alt Mode) or Thunderbolt 3 device to an HDMI display. The display cable supports High Dynamic Range (HDR10) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the video adapter cable is ideal for:
• Creating eye-catching visuals for photography, videography, cinematography
• Displaying crisp digital signage walls
• Delivering enriched presentations
True 4K at 60Hz and HDR
The USB-C video converter cable is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840x2160) and bandwidths up to 18Gbps. The cable offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Clutter-Free Installation
At 2m (6.6ft) in length, this cable cord delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
Hassle-Free Setup
To ensure easy operation and installation, this USB-C to HDMI cable supports a seamless plug & play setup with any OS, including macOS, Windows, Linux, Chrome and Android.
CDP2HDMM2MH is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Notes:
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b
NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter cable.
  • True 4K at 60Hz and HDR
    The USB-C video converter cable is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840x2160) and bandwidths up to 18Gbps. The cable offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Clutter-Free Installation
  • Hassle-Free Setup
    To ensure easy operation and installation, this USB-C to HDMI cable supports a seamless plug & play setup with any OS, including macOS, Windows, Linux, Chrome and Android. CDP2HDMM2MH is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
Startech 6ft (2m) USB C to HDMI Cable 4K 60Hz with HDR10, Ultra HD USB Type-C to 4K HDMI 2.0b Video Adapter Cable, USB-C to HDMI HDR Monitor/Display Converter, DP 1.4 Alt Mode HBR3 - Thunderbolt 3 Compatible (CDP2HDMM2MH) - adapter cable - HDMI / USB - 2 m
Cable
Adapter cable - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Cable Length
2 m
Connector
USB-C - male (input)
Connector (Second End)
HDMI - male (output)
Thunderbolt 3 / DisplayPort 1.4
4K support, active adapter
3-year warranty
Cable Type
Adapter cable 4K support, active
Interface Supported
HDMI / USB
Cable Length
2 m
HBR3 audio support, HDR 10 support, 8/10 bit deep colour, DisplayPort Alternate Mode support, 7.1 PCM audio channel support, Realtek RTD2172U chipset
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
Connector
24 pin USB-C - male (input)
19 pin HDMI Type A - male (output)
Plug and Play, FCC, RoHS, WEEE, RCM, HDCP 2.2, HDCP 1.4
2.2 cm
1.2 cm
69 g
Shipping Width
21.8 cm
Shipping Depth
20 cm
Shipping Height
1.6 cm
Shipping Weight
78 g
Limited warranty - 3 years
GBT2 StarTech.com USB-C to HDMI Adapter Cable In Stock £27.21
GBT2 StarTech.com 10ft/3m USB-C to HDMI Adapter Cable In Stock £41.88
Length: 2m
