The 6.6ft (2m) Active Thunderbolt 4 cable enables full Thunderbolt 4 capabilities and outperforms passive cables beyond 3.3ft (1m) length. An active integrated chipset minimizes signal degradation for consistent 40Gbps output at distances of up to 6.6ft (2m), while passive cables deliver limited performance beyond 3.3ft (1m) due to signal loss.
40 Gbps for Thunderbolt 4 / 3 Devices
This Active Thunderbolt 4 cable supports data transfer rates of 40 Gbps, when connected to a Thunderbolt 4, Thunderbolt 3, or USB4-compatible source and device. It is capable of transferring data four times faster than standard USB 3.2 Gen 2 (10 Gbps) cables. USB Power Delivery 3.0 -
USB-C Compatible
The Thunderbolt 4 cable is compatible with all USB Type-C devices and can be used to charge and sync mobile devices. In addition, this cable can be used to connect and power USB-C laptops, such as MacBook and Chromebook ; and USB-C peripherals such as portable hard drives and docking stations. -
Full-8K Video
The cable supports full-8K 60Hz video and DisplayPort 1.4a, and is compatible with Display Stream Compression (DSC). Use it to connect a docking station to laptop, or a laptop to a display. -
Thunderbolt Networking
The cable can be used to daisy chain up to 6 Thunderbolt 4-enabled devices, such as laptops for peer-to-peer 10GbE networking. In addition, connect two Thunderbolt 4 laptops to transfer/migrate data.
 - StarTech.com 6ft (2m) Active Thunderbolt 4 Cable, 40Gbps, 100W PD, 4K/8K, Intel Certified, Compatible w/Thunderbolt 3/USB 3.2/DisplayPort (A40G2MB-TB4-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
 - USB-C cable
- Technology
 - Shielded
 - Active adapter, USB Power Delivery (100W), 8K60Hz support, 4K60Hz support, up to 40 Gbps data transfer rate, strain relief, DisplayPort 1.4 with DSC
- Length
 - 2 m
- Connector
 - 24 pin USB-C - male
- Connector (Second End)
 - USB 3.2 Gen 2 / USB4 / Thunderbolt 3 / Thunderbolt 4- / DisplayPort 1.4a
 - Black
 - 2-year warranty
 - USB-C cable
- Technology
 - Shielded
- Shielding Material
 - Aluminum-polyester foil with tinned copper braid
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 30/32
- Plated Connector
 - Nickel
- Length
 - 2 m
- Outside Diameter
 - 4.7 mm
 - Black
- Connector
 - USB 3.2 Gen 2 / USB4 / Thunderbolt 3 / Thunderbolt 4- / DisplayPort 1.4a, FCC, RoHS, WEEE, Thunderbolt 4
- Shipping Width
 - 22 cm
- Shipping Depth
 - 12.8 cm
- Shipping Height
 - 1.6 cm
- Shipping Weight
 - 89 g
 - 2-year warranty
                        StarTech.com 1m USB4 Cable, USB-C 40 Gbps | In Stock | £20.01 |
                        StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £18.91 |
