The StarTech.com Socket 7/370 CPU Cooler with its 2cm fan cooling fan is a combination heatsink and fan designed to cool high-performance CPUs. It sports an extra-large heatsink with enough cooling capacity for Pentium III and Celeron CPUs up to 1.4 GHz. A quiet running 6x2 cm brushless ball bearing DC motor coupled with a high-efficiency blade design is capable of moving 21.46 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status. For LP4 connection, add optional accessory CPUFANADAPT.
- StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan w/ Heatsink & TX3 connector (FAN370PRO) - processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket 370, Socket 7
- Fan Diameter
- 60 mm
- Fan Height
- 20 mm
- Rotation Speed
- 4000 rpm
- Air Flow
- 20.2 cfm
- Noise Level
- 31 dBA
- Power Connector
- 3-pin plug
- Ball bearing
- 1-year warranty
- Product Type
- Processor cooler
Heatsink & Fan
- Compatible With
- Heatsink Dimensions
- 66 mm x 60 mm x 25 mm
- Thermal Resistance
- 0.64 °C/W
- Fan Diameter
- 60 mm
- Fan Height
- 20 mm
- Rotation Speed
- 4000 rpm
- Air Flow
- 20.2 cfm
- Noise Level
- 31 dBA
- Power Connector
- 3-pin plug
- Ball bearing
- Limited warranty: - 1 year
