StarTech.com 65W USB-C Laptop Charger
Quicklinx: JG73WS00 Mfr#: 165LU-USB-C-CHARGER
More than 50 In Stock
£23.19 ex VAT
£27.82 inc VAT
Power and charge your laptop with this compact 65W USB-C adapter, using the built-in 1.5m cable
Powerful, Fast USB-C Charging
This USB-C power adapter delivers up to 65W of Power Delivery 3.0/2.0 power with broad voltage support (5V, 9V, 12V, 15V, 20V), letting you quickly and safely charge a wide range of devices, replacing multiple chargers with one dependable solution.
Universal Compatibility with Leading Brands
Designed for use with popular USB-C devices including Dell Pro/Plus, HP, HP ProBook, MacBook Pro, and Microsoft Surface Pro, this charger includes a 1.8m power cord and a 1.5m tethered USB-C cable for extended reach and reliable, always-ready power, ideal for mobile or hybrid work.
Safe, Reliable, and Efficient Performance
Built to keep both users and devices protected, it is ETL Safety Listed (IEC 62368-1) and CE/FCC/ICES EMC certified, with over-voltage, current, and temperature protection. Its efficient design meets DOE Level VI standards for energy efficiency.
Eco-Friendly, Plastic-Reduced Packaging
Packaged with sustainability in mind, the recyclable brown box minimizes environmental impact and is compact to prevent product movement or damage during transport.
Startech power adapter - USB-C - USB-C - 65 watt
Power adapter
Mobile phone, laptop
8.95 cm x 6.7 cm x 2.6 cm
329 g
United Kingdom
Output Connector Type
USB-C
AC 100-240 V (50 - 60 Hz)
Voltage Provided
5 / 9 / 12 /15 / 20 V
Max Electric Current
5 A
Fast Charge Technology
Power Delivery 3.0
Power Provided
65 watt
Power Device Details
AC power adapter 24 pin USB-C - 65 W
Cables
AC input cable - 1.8 m , USB-C built-in cable - 1.5 m
Power adapter
8.95 cm
6.7 cm
2.6 cm
329 g
Enclosure Colour
United Kingdom
Input Connectors
Input Connectors Qty
1
Voltage Provided
Output connectors
24 pin USB-C
Power Provided
65 watt
5 A
AC power adapter: 24 pin USB-C - 65 W
Power Delivery 3.0
Over voltage protection, over-current protection, compact design, fast charging, over-temperature protection
Material
Plastic
EMC, FCC, RoHS, WEEE, ICES, IEC 62368-1, DoE Level VI, USB Power Delivery 3.0
Shipping Width
16.8 cm
Shipping Depth
10.4 cm
Shipping Height
7.2 cm
Shipping Weight
345 g
