Power and charge your laptop with this compact 65W USB-C adapter, using the built-in 1.5m cable
Powerful, Fast USB-C Charging
This USB-C power adapter delivers up to 65W of Power Delivery 3.0/2.0 power with broad voltage support (5V, 9V, 12V, 15V, 20V), letting you quickly and safely charge a wide range of devices, replacing multiple chargers with one dependable solution.
Universal Compatibility with Leading Brands
Designed for use with popular USB-C devices including Dell Pro/Plus, HP, HP ProBook, MacBook Pro, and Microsoft Surface Pro, this charger includes a 1.8m power cord and a 1.5m tethered USB-C cable for extended reach and reliable, always-ready power, ideal for mobile or hybrid work.
Safe, Reliable, and Efficient Performance
Built to keep both users and devices protected, it is ETL Safety Listed (IEC 62368-1) and CE/FCC/ICES EMC certified, with over-voltage, current, and temperature protection. Its efficient design meets DOE Level VI standards for energy efficiency.
Eco-Friendly, Plastic-Reduced Packaging
Packaged with sustainability in mind, the recyclable brown box minimizes environmental impact and is compact to prevent product movement or damage during transport.
- Startech power adapter - USB-C - USB-C - 65 watt
- Product Type
- Power adapter
- Designed For
- Mobile phone, laptop
- 8.95 cm x 6.7 cm x 2.6 cm
- 329 g
- Black
- Localisation
- United Kingdom
- Output Connector Type
- USB-C
- Voltage Required
- AC 100-240 V (50 - 60 Hz)
- Voltage Provided
- 5 / 9 / 12 /15 / 20 V
- Max Electric Current
- 5 A
- Fast Charge Technology
- Power Delivery 3.0
- Power Provided
- 65 watt
- Power Device Details
- AC power adapter 24 pin USB-C - 65 W
- Cables
- AC input cable - 1.8 m ¦ USB-C built-in cable - 1.5 m
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- 8.95 cm
- 6.7 cm
- 2.6 cm
- 329 g
- Enclosure Colour
- Black
- Localisation
- United Kingdom
- Voltage Required
- Input Connectors
- Power
- Input Connectors Qty
- 1
- Voltage Provided
- Output connectors
- 24 pin USB-C
- Power Provided
- 65 watt
- 5 A
- AC power adapter: 24 pin USB-C - 65 W
- Over voltage protection, over-current protection, compact design, fast charging, over-temperature protection
- Material
- Plastic
- Cables Included
- EMC, FCC, RoHS, WEEE, ICES, IEC 62368-1, DoE Level VI, USB Power Delivery 3.0
- Shipping Width
- 16.8 cm
- Shipping Depth
- 10.4 cm
- Shipping Height
- 7.2 cm
- Shipping Weight
- 345 g
- Limited warranty - 2 years
