This 6cm x 2.5cm (5000 RPM) Computer Case Fan helps prevent computer systems from overheating, thereby increasing efficiency and stability.
The fan features a TX3 connection and a built-in tachometer that sends RPM signals to your motherboard - a high-performance solution that can help avoid overheating and system failure.
- StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X25TX3H) - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 60 mm
- 6 cm x 6 cm x 2.5 cm
- 25 g
- Fan speed monitoring
- 1-year warranty
- Designed For
- P/N: RMC4450
- Product Type
- System fan kit
- 6 cm
- 6 cm
- 2.5 cm
- 25 g
Heatsink & Fan
- Fan Diameter
- 60 mm
- Limited warranty: replacement - 1 year , Parts and labour
- Designed For
- StarTech.com 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply
