Overheating hardware can be a problem in most server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations.
- StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X1TX3) - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 60 mm
- Noise Level
- 28 dB
- Dual ball bearing
- 1 cm x 6 cm x 6 cm
- 38 g
- 2-year warranty
- Product Type
- System fan kit
- 1 cm
- 6 cm
- 6 cm
- 38 g
- Shipping Dimensions (WxDxH) / Weight
- 48 g
Heatsink & Fan
- Fan Diameter
- 60 mm
- Noise Level
- 28 dB
- Dual ball bearing
- Limited warranty: - 2 years
- -10 °C
- 80 °C
