StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
Quicklinx: 4041WS00 Mfr#: FAN6X1TX3
Type: Case Fan
10 In Stock
£5.81 ex VAT
£6.97 inc VAT
Overheating hardware can be a problem in most server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations.
  • Reliable design
    The dual ball bearing design of this fan promotes longevity and stable performance, making it suitable for continuous operation.
  • Quiet operation
    With a noise level of 28 dB, this fan ensures a peaceful environment while effectively cooling the system.
  • Broad temperature tolerance
    This fan functions efficiently across a temperature range from -10°C to 80°C, accommodating various computing scenarios.
StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X1TX3) - system fan kit
System fan kit
Fan Diameter
60 mm
Noise Level
28 dB
Dual ball bearing
1 cm x 6 cm x 6 cm
38 g
System fan kit
1 cm
6 cm
6 cm
38 g
48 g
Heatsink & Fan
Fan Diameter
60 mm
Noise Level
28 dB
Dual ball bearing
Limited warranty: - 2 years
-10 °C
80 °C
4041 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.81
Type: Case Fan
