StarTech.com 60W PoE+ Fiber to Ethernet Media Converter
Quicklinx: G3QPWS00 Mfr#: IMC1GSFP60W
£165.03 ex VAT
£198.03 inc VAT
This open SFP PoE fiber media converter offers an easy, inexpensive way to extend the reach of your data and power devices at remote locations using your network over fiber, using the SFP of your choice. It combines the data connectivity of a media converter with the flexible power supply capabilities of a PoE injector. The converter provides a powerful networking solution for campuses, warehouses, factories or any applications that require POE and connectivity over long distances.
  • Designed for harsh environments
    This media converter can be installed almost anywhere you need it as it has been engineered to work in environments with large temperature changes.
  • Open SFP slot to leverage your current infrastructure
    The Gigabit fiber media converter provides a cost-efficient way to connect remote devices over a fiber link.
  • Dual power inputs
    Accepts terminal block power or coaxial power connectors with the barrel plug adapter, allowing the product to be hardwired or powered using an external power supply.
StarTech.com PoE+ Industrial Fiber to Ethernet Media Converter 60W, SFP to RJ45, Singlemode/Multimode Fiber to Copper Gigabit Ethernet, Compact, IP-30/ -40 to +75C, PoE+ Media Converter - Fiber Media Converter (IMC1GSFP60W) - fibre media converter - 10Mb LAN, 100Mb LAN, 1GbE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
DIN rail mountable
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Max Transfer Distance
10 km
Power Over Ethernet (PoE)
PoE+
8.15 cm x 10.4 cm x 3.2 cm
153 g
DIN rail mountable
Wired
Cabling Type
Data Transfer Rate
1 Gbps
10 km
Status Indicators
Port status, active, PoE, link
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, 512KB packet buffer, 2KV Surge protection, 16 KB Jumbo Frame
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
1 x Ethernet 1000Base-T - RJ-45 female - 60 W , 1 x Ethernet 1000Base-SX - SFP female
Power terminal block
Mounting Kit
Included
MTBF
561556 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6, IEEE 802.3af, IEEE 802.3at
PoE+
External power adapter
8.15 cm
10.4 cm
3.2 cm
153 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
400 g
-40 °C
75 °C
5 - 95% (non-condensing)
Type: Fibre Media Converter
