StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P06WS00 Mfr#: MXT101MMHQ60
Length: 18.3m
25 in stock
£32.82 ex VAT
£39.38 inc VAT
Connect your VGA monitor with the highest quality connection available. This 60-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 18.3 m
VGA cable
Triple shielded twisted pair coaxial
Ferrite bead
Length
18.3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Ferrite bead
Length
18.3 m
Connector
NEC-CMG
7P06 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
Length: 18.3m
Price Range Ex VAT: 0 - 50
