Connect your VGA monitor with the highest quality connection available. This 60-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 60 ft. (18.3 m) VGA to VGA Cable - HD15 Male to HD15 Male - Coaxial High Resolution - High Quality - VGA Monitor Cable (MXT101MMHQ60) - VGA cable - 18.3 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Ferrite bead
- Length
- 18.3 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAFC
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Ferrite bead
- Length
- 18.3 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- NEC-CMG
- Designed For
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.33 |
StarTech.com USB C to VGA Adapter 1080p | In Stock | £8.18 |
