StarTech.com 6 ft USB to Parallel Printer Adapter - M/M
Quicklinx: 404TWS00 Mfr#: ICUSB1284
Type: Parallel adapter
Compatibility: PC
Interface: USB 2.0
Stock Status: In Stock, Used Stock
Select:
  • Windows 8 (32/64 bits)
More than 50 in stock
£8.89 ex VAT
£10.66 inc VAT
Add a Centronics parallel port to your desktop or laptop PC through USB. The ICUSB1284 6 ft USB to Parallel Printer Adapter - M/M allows USB capable PCs to print to any standard parallel printer, converting a USB port into a Centronics (male) connector for direct connection to a parallel printer.
The USB interface provides a much faster data transfer rate than standard parallel ports, thereby reducing the time spent waiting for a print job or data transfer to be sent.
A portable, space-saving solution, the USB to Parallel Printer Adapter is self-powered and provides Plug and Play installation on Windows based, USB-compliant computers.
StarTech.com USB to Parallel Printer Adapter - parallel adapter
Parallel adapter
External
Interface (Bus) Type
USB 2.0
Ports
IEEE 1284
Length
1.86 m
Parallel
PL-2305 - Prolific
Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
1-year warranty
Parallel adapter
External
USB 2.0
Ports
IEEE 1284
Wired
Parallel
USB powered
Processor / Memory
PL-2305 - Prolific
1 x IEEE 1284 (EPP/ECP) - 36 PIN Centronics - male
Length
1.86 m
Limited warranty - 1 year
5 °C
0 - 80%
404T StarTech.com 6 ft USB to Parallel Printer Adapter - M/M In Stock £8.89
404T StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
404T StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable - M/F In Stock £14.59
404T StarTech.com 10 ft USB to Parallel Printer Adapter - M/M In Stock £17.61
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 404T 040881
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £5.98
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatibility: PC
Interface: USB 2.0
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
