StarTech.com 6 ft USB to Parallel Printer Adapter - M/M
Quicklinx: 404TWS00 Mfr#: ICUSB1284
Type: Parallel adapter
Compatibility: PC
Interface: USB 2.0
Select:
33 In Stock
£11.98 ex VAT
£14.37 inc VAT
Add a Centronics parallel port to your desktop or laptop PC through USB. The ICUSB1284 6 ft USB to Parallel Printer Adapter - M/M allows USB capable PCs to print to any standard parallel printer, converting a USB port into a Centronics (male) connector for direct connection to a parallel printer.
The USB interface provides a much faster data transfer rate than standard parallel ports, thereby reducing the time spent waiting for a print job or data transfer to be sent.
A portable, space-saving solution, the USB to Parallel Printer Adapter is self-powered and provides Plug and Play installation on Windows based, USB-compliant computers.
  • Reliable connectivity
    This adapter provides a solid connection between USB devices and parallel printers or peripherals, ensuring efficient data transfer protocols.
  • Versatile environmental compatibility
    Operating efficiently from 5 °C to 40 °C and maintaining functionality in humidity levels from 0% to 80%, this adapter is suitable for various environments.
  • Ease of use
    With its Plug-and-Play functionality, this USB to Parallel Port Adapter allows for straightforward installation and immediate use without complex configurations.
StarTech.com 6 ft. (1.8 m) USB to Parallel Port Adapter - IEEE-1284 - Male/Male - USB to Centronics Cable (ICUSB1284) - parallel adapter - USB 2.0 - IEEE 1284
Parallel adapter
External
Interface (Bus) Type
USB 2.0
Ports
IEEE 1284
Length
1.86 m
Parallel
Prolific PL-2305
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows 98SE/2000/ME/XP/Vista/7/8/8.1/10, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
1-year warranty
Parallel adapter
External
USB 2.0
Ports
IEEE 1284
Wired
Parallel
USB powered
Processor / Memory
Prolific PL-2305
1 x IEEE 1284 (EPP/ECP) - 36 PIN Centronics - male
Length
1.86 m
Limited warranty - 1 year
5 °C
0 - 80%
404T StarTech.com 6 ft USB to Parallel Printer Adapter - M/M In Stock £11.98
404T StarTech.com 10 ft USB to Parallel Printer Adapter - M/M In Stock £18.67
Compatibility: PC
Interface: USB 2.0
