StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable - M/F
Quicklinx: 5CB6WS00 Mfr#: ICUSB1284D25
Select:
Add a DB25 parallel port to your desktop or laptop PC through USB. The ICUSB1284D25 6 ft USB to DB25 parallel printer adapter cable turns an available USB port on a host PC into a DB25 female parallel port - allowing you to connect a DB25 printer to the computer as if the necessary parallel port was built-on.
A cost-effective and reliable solution, the USB to DB25 adapter saves the expense of replacing a parallel printer for the sake of USB capability.
  • Reliable connectivity
    This cable enables reliable connections between USB and parallel devices, ensuring effective communication between modern systems and legacy printers.
  • Flexible length
    At 6 ft / 2m, the cable length allows for easy setup and arrangement, making it suitable for various workspace configurations.
StarTech.com 6 ft / 2m USB to DB25 Parallel Printer Adapter Cable - 2 Meter USB to IEEE-1284 Printer Cable - USB A to DB25 M/F (ICUSB1284D25) - parallel adapter - USB 2.0 - IEEE 1284
Parallel adapter
External
Interface (Bus) Type
USB 2.0
Ports
IEEE 1284
Length
1.86 m
Parallel
Data Transfer Rate
1.5 Mbps
Prolific PL-2305
Microsoft Windows 98 Second Edition, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/ME/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11
Parallel adapter
External
USB 2.0
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.5 Mbps
Processor / Memory
Prolific PL-2305
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female
FCC, RoHS
Length
1.86 m
5CB6 StarTech.com 6 ft USB to Parallel Printer Adapter - M/M In Stock £11.95
5CB6 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.54
5CB6 StarTech.com 10 ft USB to Parallel Printer Adapter - M/M In Stock £18.60
