StarTech.com 6 ft USB C to DP Cable - White
Quicklinx: D4SWWS00 Mfr#: CDP2DPMM6W
£9.79 ex VAT
£11.74 inc VAT
Use this USB-C to DP cable to connect your USB Type C computer directly to a monitor without additional adapters. This USB-C to DisplayPort cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 1.8 m (6 ft.) away.
The adapter works with USB-C devices that support DP Alt Mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 6 ft. (1.8 m) in length, this DisplayPort cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. Plus, the USB-C cable's all-white design makes it an attractive accessory for your HP ENVY or MacBook with USB-C. If you're looking for a shorter white USB-C to DisplayPort cable, StarTech.com also offers a White 3 ft. (1 m) USB-C to DP Cable (CDP2DPMM1MW).
While the adapter looks great next to computers like your Mac and HP ENVY, it works with any USB-C computer that supports DisplayPort Alt Mode, such as your Dell XPS, Ultrabook or other Windows laptop. But if you're looking for a black cable to match your workstation, StarTech.com offers a full line of black USB-C to DisplayPort cables including: a Black 3 ft. (1 m) USB-C to DP cable (CDP2DPMM1MB), and a Black 6 ft. (1.8 m) USB-C to DP cable), which enables you to choose the right color and cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower resolution displays, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
  • High performance
    White 6'/1.8m USB-C DP Alt Mode to DisplayPort 1.2 (21.6Gbps) Cable supports 4K 60Hz UHD (3840x2160), HBR2, 5.1ch Audio, HDCP 2.2/1.4, 1080p & Thunderbolt 3 compatible.
  • Integrated video adapter cable
    USB C to DisplayPort 1.2 cable (male/male) reduces clutter, minimizes signal loss/failure points & has slim host & display connectors that fit in tight spaces.
  • Display compatibility
    USB-C to DP cable is tested & verified w/full range of DP monitors, including brands Dell, Samsung, Asus, Acer & LG; white cable compliments LCD/LED displays w/white housing/backing.
  • Easy to use
    DisplayPort over USB-C converter cable w/driverless setup works w/any USB Type-C/Thunderbolt 3 (DP Alt Mode) device; compatible w/macOS, iPadOS, Windows 10, Chrome OS, Android & Linux.
StarTech.com 6ft/1.8m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Works with Thunderbolt 3, White - USB-C Male to DP Male (CDP2DPMM6W) - DisplayPort cable - 24 pin USB-C to DisplayPort - 1.8 m
DisplayPort cable
4K60Hz (3840 x 2160) support, HBR2 support, DisplayPort Alternate Mode support, 21.6 Gbps data rate, 5.1 audio channel support
Length
1.8 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - male (output)
Displayport 1.2/Thunderbolt 3
White
3-year warranty
DisplayPort cable
Length
1.8 m
White
53 g
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.9 cm
Shipping Weight
60 g
3-year warranty
D4SW StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.75
D4SW StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
D4SW StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
D4SW StarTech.com 1m USB-C to VGA Cable In Stock £19.38
D4SW StarTech.com 2m USB-C to VGA Cable In Stock £22.00
D4SW StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
D4SW StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
D4SW StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £10.51
D4SW StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.26
