This high quality 6ft USB A-A extension cable features one USB A male connector and one USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
- StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F - USB extension cable - USB (M) to USB (F) - 6 ft - molded - USBEXTAA_6 - USB extension cable - USB to USB - 1.8 m
- Molded
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Limited lifetime warranty
- Designed For
- P/N: RKCONS1901GB, UUSBOTG
- Molded
- Length
- 1.8 m
- Connector
- Designed For
StarTech.com USB A Gender Changer - F/F | In Stock | £4.75 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
