The SVUSBVGA6 6-foot 2-in-1 USB KVM cable is specifically designed to work with any of the StarTech.com VGA USB KVM switches, helping to reduce tangles while maintaining excellent connectivity and performance.
To reduce clutter and optimize cable management efficiency, this professional grade USB KVM cable features an ultra-thin design that combines VGA and USB connectors into a single cable, making it ideal for connecting KVM switches inside a cabinet.
This high-performance 2-in-1 cable provides excellent video quality even for applications requiring high resolution performance.
- StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable (SVUSBVGA6) - keyboard / video / mouse (KVM) cable - 1.8 m
- Keyboard / video / mouse (KVM) cable
- Colour-coded connectors
- Length
- 1.8 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
- Connectors (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV441DUSBI, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
- Length
- 1.8 m
- Black
- Connectors
- PC 99, RoHS
- Designed For
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £8.74 |
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £265.47 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £464.07 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.41 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £527.07 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £280.59 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.20 |
