StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable
Quicklinx: 7RXTWS00 Mfr#: SVUSBVGA6
More than 50 in stock
£6.74 ex VAT
£8.08 inc VAT
The SVUSBVGA6 6-foot 2-in-1 USB KVM cable is specifically designed to work with any of the StarTech.com VGA USB KVM switches, helping to reduce tangles while maintaining excellent connectivity and performance.
To reduce clutter and optimize cable management efficiency, this professional grade USB KVM cable features an ultra-thin design that combines VGA and USB connectors into a single cable, making it ideal for connecting KVM switches inside a cabinet.
This high-performance 2-in-1 cable provides excellent video quality even for applications requiring high resolution performance.
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable (SVUSBVGA6) - keyboard / video / mouse (KVM) cable - 1.8 m
Keyboard / video / mouse (KVM) cable
Colour-coded connectors
Length
1.8 m
Connectors
15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End)
P/N: SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV441DUSBI, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
Length
1.8 m
Connectors
PC 99, RoHS
7RXT StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £396.55
7RXT StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £221.26
7RXT StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £446.11
7RXT StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £500.73
7RXT StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £147.05
7RXT StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £257.93
7RXT StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.75
7RXT StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.74
7RXT StarTech.com 8 Port KVM Switch Modules In Stock £211.66
Stock Status: In stock
