Extend your USB 3.0 SuperSpeed cable an additional 6 feet. The USB3SEXTAA6 SuperSpeed USB 3.0 extension cable (1.8m, A-A), offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 male to female cable extends a USB 3.0 cable connection by up to 1.8 meters and delivers the full USB 3.0 bandwidth of 5Gbps, supporting maximum throughput between compatible devices when used with a USB 3.0 host and device.
The USB 3.0 extension cord features high quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F - 2m USB 3 Extension Cable (USB3SEXTAA6) - USB extension cable - USB Type A to USB Type A - 1.8 m
- Technology
- Shielded twisted pair (STP)
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB 3.0
- Limited lifetime warranty
- Designed For
- StarTech.com 4-Port Industrial USB 3.0 5Gbps Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD and Surge Protection, DIN/Wall/Desk Mountable USB-A Hub, USB Expansion Hub with Locking Ports - Metal Construction (5G4AINDNP-USB-A-HUB)
- Technology
- Length
- 1.8 m
- Connector
- USB 3.0
- Designed For
